You guys make it look soooo easy! But I'll be darned if I can't break loose the 13mm bolts holding the bracket onto the axle. Everything was smooth sailing up until that point, but the rotors are stuck if I can't get the brackets off...all the bolts are on there (each side) unbelievably tight...
Oct 12, 2009 at 1:50 AM
