blower motor fan speed
2004 CHEVROLET MALIBU
42,000 MILES • 6 CYL • FWD • AUTOMATIC
2004CHEVYCLASSIC
I have a 2004 Chevy Classic. The fan will not run when the speed control switch is on 1, 2, or 3, but will on 4 or 5. What needs to be replaced, and where would that be located. Is this possible to do by myself? I have moderate mechanic skills.
Jul 19, 2008 at 7:05 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Most likely it is your Blower Motor Resistor.... Look like this....
https://www.2carpros.com/forum/automotive_pictures/188069_04malibubmr_1.jpg
Located on rear of unit......
https://www.2carpros.com/forum/automotive_pictures/188069_04malibubmrlocat_1.jpg
Jul 19, 2008 at 9:27 PM
ALEX HILL
The blower motor does not work on speeds 1 or 2. It works on all other setting. Fuses are all fine. Can you help?
Jan 29, 2021 at 10:16 AM (Merged)
2CARPRO JACK
  • 11,533 POSTS
Sounds like the fan speed resistor. Should be in the HVAC plenum near the blower motor, follow the wires from the blower motor to find it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JOHN LACKO
This vehicle has a 5 speed fan for both heating and cooling. Recently I've noticed that the fan operates in only 4 and 5. I've checked the appropriate fuses on the side access panel on the driver's side of the dash as well as the fuse block on the driver's side under the hood. I've pulled the heater control assembly out of the counsel and tested the switch. It has continuity for all 5 positions. Is there a switch/control under the hood that I am missing?
Jan 29, 2021 at 10:17 AM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
yes you are missing the heater resistor, located under the passengers hush panel. right next to the blower motor. you will see the wires from the blower motor go to it. there are 3 5.5mm or 7/32 screws that hold it in. every single malibu in america needs one. its a ceramic board that will be melted. the new updated one is much heavier. very inexpensive fix.
