2002 Chevy Malibu Car engine jerks when gear is changed to
2002 CHEVROLET MALIBU
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
RNCHANJR
Hi, I have problem with my 2002 Malibu and hope that you could help me solve the problem.
When I change the gear to D or R, the engine jerks. When I start to drive, it jerks when it changes the gear at low speed. I tried to fix it before by moving a sensor near the bottom-left side of the engine. After I adjust the sensor, it will not jerk. But it will come again the next day, so I have to adjust it again.
Until I drove it in a long distance, it got overheated because of a water tube leak. We replaced the rubber tube and replaced the cylinder heads.
Now, more problems occured after the overheat. 1. The fan does not work anymore. It works only when the a/c is turned on, but only the slow fan. We already replaced one sensor because we thought that it is causing the fan not to function.
2. The engine jerk is not removed anymore by moving the sensors.
3. There is a squeaking sound in the tensioner.
What should I do to fix these problems?
Thanks in advance.
Dec 28, 2009 at 7:57 AM
Chances are the tensionier needs replaced. Also, what sensor are you moving? Is it the crank sensor? THe only sensors that change the transmission are the shift solenoids or the trans control modlue (TCM). If it jumping the way you described, I would start by checking the motor mounts or trans mount.
Check that and let me know. Also, has the check engine light ever come on?
Jan 16, 2010 at 10:18 PM
