[quote:181ac20854="garcon98"]Engine Cooling problem
2004 Chevy Malibu 4 cyl Front Wheel Drive Automatic 42,000 miles
i have a haynes manual that tells me about a radiator plug wich i cannot find this has no radiator cap only a reservoir tank i wanna flush the coolant to replace the dexcool before it eats a few things !the hoses are both mid way of the radiator no upper as the older models do i need to remove the hoses and radiator to flush this puppy good ? thanks denis[/quote:181ac20854]
Hi Denis,
What is the reason for the Flush? You only have 42k on it and the life of dexcool is 100k....
Also before use a chemical flush check a and see if you have Aluminum Heads if you do, I wouldn't use a chemical flush. The flow of the coolant between the aluminum head and a cast block will create and eletrical current and cause engine problems.
One other thing if you do use a chemical flush make sure you read the container, If I am not mistaken you do not drive the vehicle while doing the chemical flush.
Nov 12, 2018 at 4:27 PM
(Merged)
