2001 Chevy Malibu white smoke coming out the exhaust pipes
2001 CHEVROLET MALIBU
145,555 MILES • 6 CYL • 2WD • AUTOMATIC
TENNA
  • 7 POSTS
ok i recently just got a oil change 2 weeks ago now when im at a red light or something and i excelerate fast white smoke comes out the exhaust pipes what is that and what should i do
Apr 2, 2009 at 7:30 PM
SOUFCAROLINA29
The white smoke usually means water is getting into your engine. It could be from the head gasket. You definitely want to get that checked out immediately.
Apr 2, 2009 at 9:02 PM
TENNA
  • 7 POSTS
so if i replace my water pump would that resolve my problems cause i took it to the shop and they say just buy a new engine i cant afford that
Apr 3, 2009 at 2:45 PM
SOUFCAROLINA29
Replacing the water pump isnt going to solve that problem. I have a friend with a 2001 Impala that had the same problem. He had to replace his head gasket. U could have a bad intake gasket, head gasket or bad seals. Either way I would take it to a professional. Replacing a gasket is cheaper than an entire engine.
Apr 4, 2009 at 12:55 AM
TENNA
  • 7 POSTS
so why did it wait till i got a oil change for this to start happening
Apr 5, 2009 at 2:51 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c07ab8ba3e="tenna"]so why did it wait till i got a oil change for this to start happening[/quote:c07ab8ba3e]
soufcarolina29 is correct about it being a head gasket or intake gasket. And you should have it checked and repaired as soon as you can. Any garage that says you need a new engine, don't deal with. However if you run it to long you can and will do enough damage to the engine that you will need a new engine.
It was just a coincidence. If you had been later getting the oil change it would have happen before hand. There is no set time or place that a head gasket or intake gasket or for that matter any gasket or seal in an engine to decide it has had enough and it fail.
Apr 5, 2009 at 3:48 PM
TENNA
  • 7 POSTS
so how much does a head gasket job runs
Apr 5, 2009 at 5:34 PM
OBXAUTOMEDIC
  • 3,711 POSTS
A lot will depend on the labor rate and parts cost in your area. It can cost from $1,000 - $1,500.
Apr 5, 2009 at 8:13 PM
