Bought from a tow lot, so not sure of past problems. Crank and tries to start. If you give it throttle while cranking, it starts right away. Rough idle after start up. Had a catalyst code (not sure what the actual code was as my good friend who plugged into it cleared them after reading it) but now no codes are present. Checked fuel pressure and was getting 45-55 with key on and 55-63 while running. After shut down the fuel pressure drops off to near zero, same with just the key cycle. Key on 55, and then it drops off after a few seconds...Any advice?
Sep 9, 2010 at 12:04 AM
