Camshaft sensor location
2001 CHEVROLET MALIBU
KMALLINGER
Hi, I need to know where the camshaft sensor is located and how difficult it is to replace it?
Sep 2, 2009 at 4:24 PM
1. Turn OFF the ignition.
2. Remove the power steering pump.
3. Disconnect the sensor electrical connector.
4. Remove the attaching bolt.
5. Remove the sensor.
6. Inspect the sensor O-ring for wear, cracks or leakage if the sensor is not being replaced.
INSTALLATION PROCEDURE
1. Lubricate the O-ring with clean engine oil. Replace the O-ring if the O-ring is damaged.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the camshaft position sensor.
Tighten
Tighten the retaining bolt to 8 N.m (71 lb in).
3. Connect the sensor electrical connector.
4. Install the power steering pump.
See diagram below
Sep 2, 2009 at 4:41 PM
FERN-ZERENEJACQUES
If you still need an answer the camshaft sensor is located under the power steering pump. I just changed mine and it took about thirty minutes. Remove the power steering pump and the sensor needs a 8mm and a screwdriver to pop out.
Apr 5, 2013 at 7:43 PM
