front end shakes
2000 CHEVROLET MALIBU
16,000 MILES • 6 CYL • FWD • AUTOMATIC
GEORGEJH
i think i have front end damage but im not sure exactly what it is, my steering wheel is completely turned, my car shakes, rattles, at 65 mph i go through tires every other week.
Nov 16, 2009 at 9:44 PM
KNOWYOURAUTO
  • 113 POSTS
Hello it sounds like your alignment is way off or you have a bent tie rod. A steering wheel a little off center may be an alignment. A steering wheel turned almost 90 degrees is a bent component. In these cases several components. If you are a little auto savvy, inspect the tie rods for damage by comparing the left to right side. They should be straight. These are the easiest to bend.
https://www.2carpros.com/forum/automotive_pictures/435113_tie_rod_1.jpg
Also inspect the control are for damage. It may be easier to have a shop inspect it for $20 and give you a full estimate of the parts. Most are easy to install, but an alignment will be required regardless.
https://www.2carpros.com/forum/automotive_pictures/435113_suspension_1.jpg
In a worst case the frame may also be bent and would then require extensive work. Good luck,
Nov 17, 2009 at 1:10 PM
