Last winter the button that activates the rear window defogger worked intermittent, this year it doesn't work at all. I have taken the button apart, it looks fine, replaced the relay, and checked continuity on the defogger grid and its fine. Is this a common problem, and if so, what needs to be replaced/fixed? Also, the blower control only works on setting 3 and higher, 1&2 produce nothing. Is this related? It would seem to be a different circuit, so what is the issue with that. Any help would be greatly appreciated. Overnight temp -25C, Brrrrr.
Nov 23, 2008 at 12:39 AM
