1999 Chevy Malibu RADIO WIRING
1999 CHEVROLET MALIBU
FOURMVP
Electrical problem
1999 Chevy Malibu 6 cyl Wheel Drive Type unknown Automatic 175453 miles
trying to install a new radio and i need to know what each wire is off of the factory harness the new radio harness has only one clip so i have to cut the factory harnesss to wire it up need to know what color wire is what.
Dec 17, 2007 at 11:21 AM
CARLUCCIJA
  • 29 POSTS
if you bought a wiring harness for that car. The harness is made to go on the factory radio harness then you wire your new radio on the wiring harness you bought. you shouldn't have to cut the factory harness. If their are two factory harnesses. you might have bought the wrong harness for your car.check and make sure you have the correct one for your car, before you cut the factory harness
Dec 18, 2007 at 3:37 PM
BMRFIXIT
  • 19,053 POSTS
[quote:4a7edae9a4="fourmvp"]Electrical problem
trying to install a new radio and i need to know what each wire is off of the factory harness the new radio harness has only one clip so i have to cut the factory harnesss to wire it up need to know what color wire is what.[/quote:4a7edae9a4]
is it with or with out remote playback
dont cut the wire buy a plug for it all you have to do is match color with new radio
Dec 19, 2007 at 5:00 PM
