1998 Chevy Malibu whats this codes means
1998 CHEVROLET MALIBU
SERGIO195949
Transmission problem
1998 Chevy Malibu 6 cyl All Wheel Drive Automatic
i have a chev malibu 98, I got the codes P0711 AND P1810, WHAT THIS CODES MEANS AND HOW CAN I FIX IT.
THANK YOU
May 26, 2008 at 6:37 PM
BMRFIXIT
  • 19,053 POSTS
Possible tranny need to be rebuilt
check with your local tranny shop for pricing
or check used auto part s
May 26, 2008 at 6:45 PM
DENNYP
  • 1,824 POSTS
P0711 is a TFT sensor circuit failure. P1810 is a TFP switch circuit failure. You should first inspect the connections at the 20 way connector on the transmission. If ok, check the connection at the TFP switch inside the transmission.
May 26, 2008 at 6:51 PM
SERGIO195949
I'm Sorry but let me explain. I do not think anythign is wrong with the switch or the sensor. I think they are erroring correct because i am trying to figure out what is wrong with the car. It keeps giving me these codes and right now the car will run just fine but after awhile after running the car stops shifting gears. Any reasons why? Does this mean the transmision is bad? or is it something more simple? Thanks
May 26, 2008 at 7:28 PM
SERGIO195949
May 26, 2008 at 8:11 PM
BMRFIXIT
  • 19,053 POSTS
We had the same issue last week , drive it for an hour running and shifting OK
and all of sudden delay shifting check engine light on same codes
after all checked OK
we had to drop the tranny and replaced the valve body and solenoid
so far good
May 26, 2008 at 8:36 PM
