Engine Mechanical problem
1998 Chevy Malibu 6 cyl Automatic
The intake manifold gasket was replaced. After the engine was put together the spark plugs started misfiring. It was #5 and #3, I believe. I would have to confirm with my mechanic.
The car was fine the day before the intake gasket went. Except the ECU needed to be replaced. It was causing the low idle, according to my mechanic. I was about the order it before the intake issues.
The spark plugs were replaced over the weekend along with the wires. There are no leaks from the gaskets. Camshaft position sensor is fine.
What else could it be?
Apr 7, 2010 at 8:38 AM
