1998 Chevy Malibu Constant studder
1998 CHEVROLET MALIBU
194,500 MILES • 4 CYL • FWD • AUTOMATIC
ALLSIGNS
I have a studder in the engine while accelerating. It did throw a multiple misfire code as well as a running rich code. I have replaced the spark plugs, the coil packs as well as its housing. checked compression as well as fuel pressure and those two things checked out good. I also replaced the fuel pump prior to attacking the ignition. After all of that I am still having the problem but I have not had any codes come up. any help would be much appreciated. Thank you.
Aug 26, 2008 at 9:56 PM
RHALL77
  • 3,361 POSTS
road test it with a scan tool and see what your fuel trims are. also see when you snap the throttle, what your percentage is on the MAF sensor
Aug 27, 2008 at 7:15 PM
