Engine Mechanical problem
1980 Chevy Malibu V8 Two Wheel Drive Automatic 0
I just got my short block back from the engine builder and have installed the the following: oil pump (brand new Melling HV), brand hydraulic roller cam and roller lifters, new roller rockers, brand new push rods, new timing gear & chain, new oil filter & 20w50 oil, new aluminum heads. I tried priming the engine this afternoon and the oil is not reaching the rocker arms. BTW, my engine is a Mark IV 454 bored .060 over. What can be preventing the oil from getting to the top of the heads? Again, everything is new except for the block. Keep in mind I am working in a unheated garage but it did hit 60 degrees here today. Back to the oil problem - what do I check now? Is the oil to thick? Could it be a defective oil filter? At this point I'm stumpted. Please advise what I can do, or try, to fix this problem because I have a lot of money in this engine.
Thank you.
Thank you.
Mar 3, 2008 at 10:55 PM
