I have a 72 chevelle, i recently rebuilt a 350, put larger cam bored it 30 over, new heads... juiced it up a little. it has a turbo 350 in it, and while i was driving it i put it in neutral and revved the engine to about 2500 rpms, and then shifted it back in to gear. there was a loud pop, that came from where the transmission is and the car died, i pulled over and started the car, it started fine, but when i tried to put it into gear, the transmission makes a sound like metal grinding against metal. i haven't asked too many people about the what the problem is, because im pretty sure i need a new transmission, and do you think i need a bigger transmission that will handle the motor a little better like a 400?
Mar 26, 2007 at 1:49 PM
