Replaced a leaking master cylinder. prepared to bleed
the system. pedal is very spongy and there is no
pressure and no fluid comes out of the bleeder when'the pedal is pumped 3 times then held.
When the cover is removed from the master and the pedal is pumped there is visable flow in the master.
could this be a bad rubber seal on the cover not allowing pressure to build up in the master? LOST
Mar 15, 2008 at 2:24 PM
