1997 Lumina 3.1 We just bought the car a couple of months ago, and this past weekend I was installing a remote start system, and found a weird module spliced into the yellow start wire under the dash. The yellow wire was cut, and this module had a green wire and a white wire going to the key side of the cut wire, and a red wire and a black wire going to the starter side, and then finally a brown wire and a blue wire going to ground. I suspect it is something for the VATS, because when I unplug the VATS wires coming from the key switch, the car will still start. I noticed I never got a security light, so I checked the bulb and it was burnt out. I replaced it as see why it burnt out in the first place, it is always on.
I have no idea who makes this module, and why it is there, and what problem it is covering up.
Thanks
Thanks
Oct 30, 2007 at 5:48 PM
