security light always on
CHEVROLET LUMINA
PEPI
  • 5 POSTS
1997 Lumina 3.1 We just bought the car a couple of months ago, and this past weekend I was installing a remote start system, and found a weird module spliced into the yellow start wire under the dash. The yellow wire was cut, and this module had a green wire and a white wire going to the key side of the cut wire, and a red wire and a black wire going to the starter side, and then finally a brown wire and a blue wire going to ground. I suspect it is something for the VATS, because when I unplug the VATS wires coming from the key switch, the car will still start. I noticed I never got a security light, so I checked the bulb and it was burnt out. I replaced it as see why it burnt out in the first place, it is always on.
I have no idea who makes this module, and why it is there, and what problem it is covering up.
Thanks
Oct 30, 2007 at 5:48 PM
SERVICE WRITER
  • 9,123 POSTS
Post on a pic of the module, What does it say on it?
It sounds like maybe you finanaced the car? The loan companies have been installing a modlue on the car that can shut it down by satillite if you don't make your payment on time.
Oct 31, 2007 at 7:43 PM
PEPI
  • 5 POSTS
No the car is not leased, we bought it outright, we own it 100%. I'll try to take a picture of it and post it. I does not have any markings on it at all.
Oct 31, 2007 at 7:55 PM
SERVICE WRITER
  • 9,123 POSTS
After you get it put back together correctly, I wouldn't be surprized if the ignition switch is bad. See a fair amount of GMs like that...just not butchered.
https://www.2carpros.com/forum/automotive_pictures/30961_cm1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_cm2_1.jpg
Theft deterrant module as you thought?
Oct 31, 2007 at 8:02 PM
PEPI
  • 5 POSTS
I am going to try a different ignition switch tonight. I should just add/clarify, that this is the thick 8 or 10 gauge yellow wire that is cut and this module thing is spliced into (in series) if that makes a difference.
Is there a way I could get a big pictue of that wiring diagram you posted? I have a Haynes manual, but it doesn't show it all like yours.
Thanks everyone so far!
Nov 1, 2007 at 5:38 AM
SERVICE WRITER
  • 9,123 POSTS
The picture size is limited, but this is where I get mine from:
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 1, 2007 at 5:46 AM
PEPI
  • 5 POSTS
Okay, tonight I checked the resistance down by the connector under the dash near the steering column and it was wide open (with key in ignition), so I took an extra ignition cylinder and put a spare key in it and after I replaced the bulb the security light would flash until I plugged in the spare cylinder and then it went on steady for about 10 seconds and then went out and I could start the car. So it appears to be something in the wiring to or the actual ignition switch. Problem now is before I could start the car with the VATS from the switch unplugged, and that module thing installed. Now it won't start like that. I still don't know what this thing does, and why it was intalled. I don't know if it was cheaper than replacing the ignition cylinder or what. Here are some pictures of this module. I hope I can upload them correctly. The only markings was on the heat shrink tubing, but on the piece that unplugs it had SL-1 Thanks for all the help so far!!!!
https://www.2carpros.com/forum/automotive_pictures/112315_100_0880_1.jpg
https://www.2carpros.com/forum/automotive_pictures/112315_100_0879_1.jpg
https://www.2carpros.com/forum/automotive_pictures/112315_100_0878_1.jpg
https://www.2carpros.com/forum/automotive_pictures/112315_100_0877_1.jpg
Nov 1, 2007 at 8:00 PM
