when i start my car when it is cold it tends to idle at a really high speed usually between 2500-3500 rpms sometimes if i gun it a little while still in park it will idle down and other times it takes around five minutes to idle down i was told this was somekind of air flow sensor by a friend with obd1 reader can you tell me what this sensor is called and where it might be i was told it might be on the air intake also i have had some problems with my cooling system the sensor that triggers the fans to turn on dosent seem to be working i know the fans are good because i have tested them myself manually and also have them wired to a toggle switch which i just keep turned on when running what is the name of this sensor thank you very much for your time
Nov 22, 2007 at 12:31 PM
