1999 Chevy Lumina EGR VALVE
1999 CHEVROLET LUMINA
PETEYG2
Engine Mechanical problem
1999 Chevy Lumina 6 cyl Two Wheel Drive Automatic
How do you check an egr valve and change it if bad
Mar 27, 2009 at 1:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First, locate EGR valve. Place the vehicle in park. Apply the emergency brake. Start the vehicle. Allow to warm up.
Find the EGR plunger mechanism. The EGR valve plunger meters the exhaust gas recirculation by opening and closing.
Manually rev the engine and check for plunger operation. A plunger stuck open or closed indicates EGR valve problems.
Post results of EGR valve function and I will follow up.
Thanks for using 2CarPros.com!
Mar 27, 2009 at 1:30 PM
