1999 Chevy Lumina cam shaft sensor
1999 CHEVROLET LUMINA
PILCH329
Engine Performance problem
1999 Chevy Lumina 6 cyl Front Wheel Drive Automatic
My cam shaft sensor was replaced recently and car hesitates when starting off what can cause this?
Apr 14, 2010 at 11:56 AM
LEGITIMATE007
  • 5,121 POSTS
it can be several things, I would start out with a thorough throttle body cleaning, then check the iac. (idle air control valve). make sure you have a clean air filter and gas filter. you might want to do a fuel pressure check , just to rule out fuel components. and if you havent already, be sure to do some plugs and wires.
Apr 14, 2010 at 1:18 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
