HEATER CORE
1998 CHEVROLET LUMINA
SS193329
Heater problem 6 cyl Two Wheel Drive Automatic
HOW TO INSTALL A HEATER CORE?
Dec 2, 2009 at 1:06 PM
You must start by letting the charge out of the air conditioner.
then get started under the dash removing the heater box along with the heater and ac hoses.
Here is a guide hat will show you what you are in for when doing the job.
https://www.2carpros.com/articles/replace-heater-core
Your car will be a little different but you get the idea.
May 22, 2017 at 1:52 PM
ALSMITH872
Engine Cooling problem
1998 Chevy Lumina 6 cyl Front Wheel Drive Automatic 188020 miles
I have a water leak on the hose or tube going through the firewall going to the heater core I assume this is the hose going to the heater core. The hose is in the middle of the firewall under the intake manifold. my question is, is this the hose going to the heater core ? also I can smell antifreeze coming out the heater vents . I also have a wet spot in the car floor under the heater core but i can not see the water leaking in the car, it leaks out side at the fire wall hose a lot. so can you tell me what that hosa is and do you think i need to replace the heater core ? thank you for your time.
May 22, 2017 at 1:53 PM (Merged)
Hi:
Yes that is the heater core. If you are getting coolant in the car, it is leaking inside too. If you smell coolant through the heater vents, that is the problem. It will need replaced.
BBICKERS
Heater problem
1992 Chevy Lumina 6 cyl Two Wheel Drive Automatic 94000 miles
how do i replace the heater core myself?
BLUELIGHTNIN6
  • 16,542 POSTS
Is this the Lumina Van or Lumina Sedan?
SLYCAT422
Shakes or Wobbles problem
1995 Chevy Lumina 6 cyl Front Wheel Drive Automatic 110000 miles
Hi. I replaced & correctly installed a new Waterpump & Thermostat. Checked "All 3 Relays", Fuses, checked heater control switch for fluctuating resistance w/ meter while turning knob back & 4th. It checked out ok. I flushed system 4-6 times, filled full "WATER". There's NO OBSTRUCTIONS in cooling system, yet only cold air comes out of heater core. I removed Kickpanel & Core Shroud. If the problem IS in The Heater Cont. Valve, where exactly is it located, & or what else could it be except it? Please let me know ASAP I need to get some antifreeze in it before block freezes up. Thanks Scott S. - Kennewick, WA. 99336
RENAUDTN
  • 636 POSTS
I can’t remember if your car has a heater control valve but if it does it should be in the heater core inlet hose. Also, your heater core could be plugged. When your car is idling at normal operating temp and the heat is turned on all the way, are both heater core hoses really hot? If so your core is fine; if one is cooler than the other, your heater core is clogged.
Another possibility is your vent door or your vent door actuator. When you switch from cold to hot do you hear the vent door moving behind the dash? If not look there.
LGOODLYW
  • 5 POSTS
Heater problem
1999 Chevy Lumina 6 cyl Two Wheel Drive Automatic 99902 miles
how to replace heater core 1999 chevy lumina
Hi:
Replacing the heater core is an involved process which requires removing part of the dashboard. I recommend purchasing a repair manual (Haynes, Mitchell, Chiltor) before starting. The manual will provide step by step instructions and pictures for part identification.
KATERI
Heater problem
1995 Chevy Lumina 6 cyl Front Wheel Drive Automatic 235000 miles
I've been having issues with my heating. I did a flush and changed my thermostat but my heat is not as hot as it should be and my rear heating is not working. Could my rear heater core be the problem??
May 22, 2017 at 1:54 PM (Merged)
With the engine running, rear heat on high, and the engine at normal operating temp, feel both heater core hoses. THey both should be hot. If one is cold, there is no circulation to the heater core, thus no heat.
Let me know what you find.
LGOODLYW
  • 5 POSTS
Heater problem
1999 Chevy Lumina 6 cyl Front Wheel Drive Automatic 99970 miles
how much trouble to change the heater core.thank you, when i get back to work i will make a dontation.
DOCFIXIT
  • 18,828 POSTS
Not much on your car. Remove hoses the sound panels on pass side.Then floor duct to rear then cover to core. Then remove core.
At bottom of reply you can get manual via internet click on bottom site ie. manuals.
RORYTHUNE
Heater problem
I have a 1995 lumina and the heater doesnt work. I replaced the thermostat and that didnt fix my problem. the car also overheats and it blows cold air into the cab. Once and great while i get a smell of antifreeze. what could it be im kind of thinking the heater core but not to sure
RENAUDTN
  • 636 POSTS
One way to find out if it's your heater core, is to leave the car idling at normal operating temp, and turn the heat on high; if both heater hoses are burning hot, your heater is probably fine (although it could be leaky which could explain the smell); if one of the hoses is cold or luke warm, your heater core is probably clogged. If there's a heater control valve in your system, make sure it's not stuck closed (the inlet hose will be hot up until the valve, and cold after the valve).
From what you're describing, it sounds like you need to flush your cooling system/heater core, and you may even have to replace the core depending if it's leaking or not. Again, if you have a heater control valve, make sure it's not the culprit. I can't remember if you have one or not.
Good luck
