The fuel pump runs all the time. Should cycle after a few seconds when the car is turned on but not running. It doesn't do that. The pcm is never dropping voltage to the f/p relay. This car doesn't use the oil pressure switch as the sense to cut off the pcm, I don't see anything in the wiring diag that does. What cuts off the fuel pump when the car is not running on this model.
May 1, 2008 at 9:28 AM
