The intake gaseskate is licking water into the oil what should I do for a quick fix or to fix it for good.
Dec 29, 2009 at 7:57 AM
OBXAUTOMEDIC
CERTIFIED EXPERT
Well, if you are sure it is the Intake Gasket then a good permenant fix, well probably not permenant fix, would be to replace the gasket. A temp fix you can try some stop leak.
