turn signal is not working at all?
1998 CHEVROLET LUMINA
82,000 MILES • 6 CYL • FWD • AUTOMATIC
RON NEWHOUSE
I have a 1998 Chevy Lumina with 82,000 miles, and the turn signal is not working at all. I have checked the fuse, and it is okay. Where is the turn signal flasher located.
Dec 16, 2007 at 10:31 AM
2CARPRO JACK
  • 11,533 POSTS
It is behind te left side of the dash. Probably have to remove the lower plastic panel to gain access
Dec 19, 2007 at 7:49 AM
I agree with 2CARPRO JACK, here is the location of the flasher so you can change it out and help fix the problem. The turn signal and hazard light flasher are the same FYI. Check out the images (below). Let us know if you need anything else.
Nov 6, 2024 at 1:17 PM
