1998 Chevy Lumina
1998 CHEVROLET LUMINA
BOB0001
Computer problem
1998 Chevy Lumina 6 cyl Front Wheel Drive
how can i reset the check engine light.
Apr 27, 2009 at 5:52 AM
BMRFIXIT
  • 19,053 POSTS
Before resetting check engine light should scan it for codes
as it may be something it need to be addressed soon
check engine light can be reset by using an OBDII reader ,scanner
disconnecting battery terminal for a few minutes will reset PCM and codes
if light come back on you should have to get the codes and fix it
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 27, 2009 at 5:59 AM
You need a scantool to do it or take it to autozone and have them clear it. Don't attempt to disconnect the battery you gonna run into problems-
Apr 27, 2009 at 6:06 AM
