1997 Chevy Lumina Windshield washer tubing and flow system
1997 CHEVROLET LUMINA
125,000 MILES • 6 CYL • FWD • AUTOMATIC
CASEYWILSON
  • 4 POSTS
The nipple connecting the washer tubing through the firewall is broken on the back side. It appears to be an integral part of an electrical connector. I can't find the part number. Please help.
Casey[img:d974dbc4f5]http://www.2carpros.com/forum/automotive_pictures/355158_Lumina_2_1.jpg[/img:d974dbc4f5]
May 12, 2009 at 1:55 PM
MERLIN2021
  • 17,250 POSTS
Looks more like either a vacuum tube, or washer fluid line, these Plices are available at All prts stores. Plastic TEE!
May 12, 2009 at 2:13 PM
CASEYWILSON
  • 4 POSTS
Please read again and look at the picture.
It is certainly in the washer fluid line. The problem is, the plastic nipple running through the electrical connector (see picture) is snapped off on the back side. In the picture you can see the white part still stuck in the tube. If you look at the connector inside the firewall, you can see the rubber tube attached from the washer fluid motor.
I need the part number of the connector gizmo to order another one.
May 12, 2009 at 3:30 PM
MERLIN2021
  • 17,250 POSTS
No it's the right answer, do you see ANY wire protruding? NO! You need a new plastic TEE! Remove the broken one from both ends and rejoin them...
May 12, 2009 at 4:06 PM
CASEYWILSON
  • 4 POSTS
Okay, I'll give this one last try. Please, please, please look at the pictures -- this one is a new one from the other side of the connector
Look! A wire bundle! Surprise! Hey! Look on the left of the connector, that's the other side of the broken nipple.
Please, don't bother to apologize, all I'm asking for is the part number for the connector block that goes through the firewall. If you can't provide that to me, please say so and I'll move on.
May 12, 2009 at 5:30 PM
MERLIN2021
  • 17,250 POSTS
Casey the picture I see at your first post shows a broken vac or washer nipple, not wire connector, post any others you have for the wiring connector, I will help if I can see what you are looking at. The link you posted takes me to the main page, not a picture?
May 13, 2009 at 2:52 AM
CASEYWILSON
  • 4 POSTS
This one.....
https://www.2carpros.com/forum/automotive_pictures/355158_Lumina_3_2.jpg
May 13, 2009 at 11:24 AM
MERLIN2021
  • 17,250 POSTS
I dont have a part number for it, but remove it and take it to chevy parts, or a junkyard, you will find one.
May 13, 2009 at 3:55 PM
MERLIN2021
  • 17,250 POSTS
Casey sorry I couldnt help you out, but if you do what I said you will get the part, If you want I will call Chevy today and get a part number and email it to you, I have never neeeded a part number to get a part...This electrical connector goes to the wiper washer motor? The shots you posted are real close up, the harness plugs in to what? If thats not good enough I will send Mike a note for your refund...
May 14, 2009 at 2:27 AM
MERLIN2021
  • 17,250 POSTS
For the electrical connector part go here and look up washer repair kit for your year amd make I found this.
https://www.2carpros.com/forum/automotive_pictures/62217_lumina_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_lum_1.jpg
If just the vac part isnt working, you may need to just drill a hole and connect it thru the firewall with that plastic Tee. http://www.rockauto.com/catalog/raframecatalog.php
May 14, 2009 at 2:41 AM
JAMESAVERY
  • 10 POSTS
https://www.youtube.com/watch?v=leTF13rg1-g
Title: Fix Broken Windshield Washer Fluid System Connector (Chevy Lumina 1997)
Check out this Youtube Video it should answer this question in full. Seems common.
Jun 4, 2016 at 10:15 PM
