Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Lumina
Brakes
ABS
Wheel Speed Sensor
Location
1997 Chevy Lumina wheel speed sensor
1997 CHEVROLET LUMINA
140,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVERADOMAN5
MEMBER
1 POST
FOLLOW
Where is the wheel speed sensor located on this model car. Is there one for each wheel and if so how do you determine which one is bad?
May 5, 2008 at 6:06 PM
BLACKOP555
CERTIFIED EXPERT
there is one on each wheel, you will see a "gear" at the back of the hub, the abs speed sensor gets data off of that gear.
to check them hook up a multimeter to it and turn the wheel, it should read voltage, then check for resistance and make sure its withiin specs.
May 5, 2008 at 7:28 PM
