How do I remove and install new power steering pump on a 1997 Chev Lumina 6 cylinder 3.1
Feb 12, 2008 at 5:40 PM
MASTERTECHTIM
CERTIFIED EXPERT
first of all before starting the job you will need a pulley remover to press the pulley off the pump. if you are using a used pump and it has the pulley already on it then just remove the 3 thirteen mm bolts holding it on then remove the 15 mm nut holding the lines secure. remove and replace.
