Hi there,
Bleed the brakes into a clear glass jar and use a clear plastic hose on the bleeder, something like washer hose, you should be able to get this at any auto parts shop. add a small amount of brake fluid into the jar, fit the hose over the bleeder, it must be a snug fit, place the free end into the fluid in the jar and open the bleeder, pump the pedal up and down slowly, making sure that the reservoir stays full, you will get some air first up as the hose clears, but after that, only air in the system will be seen (if any) you will see air as bubbles in the clear hose, keeping the free end in the fluid will stop air coming back up the line, when no air is seen, hold down the pedal and close the bleeder, move on to the next brake, if air is still visible the master cyl is drawing in air and should be replaced. Do not reuse old brake fluid you have bleed out.
mark (mhpautos)
Jun 4, 2010 at 6:08 PM
