Gas tank leaks by filler neck. Can the filler neck be replaced without changing the whole tank?
Nov 17, 2008 at 8:29 AM
BLACKOP555
CERTIFIED EXPERT
tank or the rubber part of the filler hose?
if its on the tank you can use some stuff called
"seal-all" you just slap that stuff on there as per directions and youll never have to worry about that leak again.
