1997 Chevy Lumina Fuel pressure
1997 CHEVROLET LUMINA
CHEVYLUMINA
Engine Performance problem
1997 Chevy Lumina 6 cyl Front Wheel Drive Automatic
I have low fuel pressure after replacing fuel pump and fuel filter and pressure regulator. What else can I check? What am I overlooking?
I have replaced fuel cap.
Apr 11, 2009 at 2:09 PM
LEGITIMATE007
  • 5,121 POSTS
I know it sounds simple but check your gas cap and make sure its good if not replace it with the correct one and make sure you twist it tight and it clicks several times after you do so. Your evap system may be causing you a problem too.
Apr 11, 2009 at 2:18 PM
