1997 Chevy Lumina
1997 CHEVROLET LUMINA
241,000 MILES • 6 CYL • FWD • AUTOMATIC
CYCLERIDER73
  • 6 POSTS
I have a 1997 Chevy Lumina. It barely holds anti-freeze at all. If i put anti-freeze in it will run fine for a little while but when I come to a stop or when I let it sit at idle the temp shoots up. When I look under the hood there is a loud hissing sound coming from under the throttle body or the intake manifold. It also looks to be wet in the same place but I can't see where the anti-freeze is coming from exactly. Please help.
Feb 14, 2009 at 4:39 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to get a cooling system pressure test done, this will help locate any external coolant leaks, the test will take just a few Minuit's.
Mark (mhpautos)
Feb 14, 2009 at 4:48 PM
CYCLERIDER73
  • 6 POSTS
Thanks, but where can I get this done? Should I go to a mechanics shop or will some place like O'rielly do it?
Feb 15, 2009 at 2:27 PM
MHPAUTOS
  • 31,937 POSTS
Your mechanic will do this for you,
Mark
Feb 15, 2009 at 3:44 PM
