I have a 1996 Chevy Lumina with a 3.1L engine. The problem I have is that the car is misfiring with some hesitation. The code P0305 is coming up on the “Service Engine Soon” light. I have changed the Spark Plugs, Wire Set, Coil for #5 Cylinder, Fuel Filter, and I put cleaner for the Fuel Injector and it is not doing anything, I have been doing that for the past 3 weeks. By the way, every time I go up a little hill or something the “Service Engine Soon” light would flash a couple times. Could you help me with that?
I have checked/replaced the following parts:
1.Spark plugs and wires
2.Fuel Filter
3.PVC Valve
4.Ignition Coil
5.Throttle Position Sensor
6.EGR Valve
7.Distributor
8. MAP Sensor
9.Air Filter
10.Coil Pack
2.Fuel Filter
3.PVC Valve
4.Ignition Coil
6.EGR Valve
7.Distributor
8. MAP Sensor
9.Air Filter
10.Coil Pack
Sep 28, 2008 at 11:05 AM
