1996 Chevy Lumina brake lights dont work
1996 CHEVROLET LUMINA
104,000 MILES • 6 CYL • FWD • AUTOMATIC
BANNANA1
no brake lights or high brake lights , replaced bulbs,brake switch,turn singal switch(s) fuse good power at swtich(brake) both sides to ground traced wires from sockets to plug in trunk pass side traced wires plug to wire block passenger side under dash all were good used ohm meter no brakes in wires .
May 29, 2010 at 10:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
there are 3 fuses for the brake light circuit, did you test all of these? does the new turn signal switch work properly?
May 29, 2010 at 10:24 PM
