i go to start the car, put key in, and turn to on position, the volts light doesn't show, and can hear a clicking noise coming from the box with relay switches. and after about 3 minutes the noise stops the fuel pump turns on and will start. thought it was the fuel pump relay, replaced that, seemed to work, but then 2 weeks later, same problem. :(
Nov 20, 2009 at 8:58 PM
