Brakes problem
1995 Chevy Lumina 6 cyl Two Wheel Drive 103226 miles
i change the rotors and brake pads and when i drive i get a knocking sound from the caliper when i removed the tire i noticed the caliper can be moved side to side all bolts are tight and its the right size rotor thickness and diameter.could it be the piston s not sitting right?
Nov 21, 2008 at 1:36 PM
