1995 Chevy Lumina Electronic Flasher
1995 CHEVROLET LUMINA
BORNO8500
Electrical problem
1995 Chevy Lumina
I am trying to locate the elctronic flasher for the hazards and turn signals but am not sure where to locate it in the car. Do you know where I can find it?
Dec 7, 2009 at 10:50 AM
DZLD9
I just found it on my car because it is having similar problems, the flasher switch is located underneath the steering column near the parking brake pedal.
You must first remove the interior panel under the steering column, and then you will see a small black box. If you look closely it is labeled "Turn/Hzd Flasher" or something of the sort.
Hope this helps.
-Zak
Dec 7, 2009 at 2:47 PM
