1995 Chevy Lumina door panel
1995 CHEVROLET LUMINA
96,000 MILES • 6 CYL • FWD • AUTOMATIC
RUSTICRADIO
Hi There,
How do I remove the front right door panel on my 95 Chevy Lumina Minivan so I can replace the window motor?
I will donate for helpful answer.
Many Thanks, Rustic
Jul 19, 2008 at 7:10 PM
STANG007
  • 29 POSTS
Look in the handle there should be a screw there. Look under the door im not sure if there are some screws there (the lumina car has some there) if not check for clips under the door. there should be clips in the top of the door too. when all screws are unscrewed just push the door upward and the clips should get out.
Jul 20, 2008 at 11:23 PM
JALOPYPAPA
  • 467 POSTS
pry out any plugs hiding screws, and any inside the arm rest, and remove the screws in the door handle recess. Pry the door lock handle off its rod. Use a screwdriver or pry tool to pop out the nylon fasteners around the bottom and sides of the panel. Unfasten the window switch wires. Pull the panel straight up. carefully pull off the plastic liner. Remove a couple more brackets. Tape up the window and remove the bolts holding it to the regulator. To remove the motor, drill/chisel out the rivets holding the regulator. Unplug the motor and pull the regulator and motor out together.
Jul 21, 2008 at 10:58 PM
