1994 Chevy Lumina front brake line repair
1994 CHEVROLET LUMINA
94,000 MILES • 6 CYL • FWD • AUTOMATIC
PARADIS51
How do i repair front brake lines?
Aug 25, 2008 at 5:36 PM
JALOPYPAPA
  • 467 POSTS
For the hose portion between the strut and the caliper, use a flare nut wrench to loosen the steel tubing from the hose. Have a pencil stub or something ready to plug the brake line with so it doesn't drip.
The hose attaches to the caliper with what's called a banjo bolt, which is hollow and goes through the connector. Make sure when you replace the hose to use a copper washer on both sides of the hole in the connector that the bolt goes through or it will leak.
When you're done, bleed the brakes.
Aug 26, 2008 at 4:34 PM
