1993 Chevy Lumina Turning signals
1993 CHEVROLET LUMINA
MERCYELVIRA42
Electrical problem
1993 Chevy Lumina 170000 miles
My turning signals have stopped working. I checked the fuse box and the fuse is fine. The hazards seem to be working, but only the right front headlight will flash. The left headlight and the taillights will not flash. The hazards are a secondary problem, at the moment. I only checked to make sure it wasn't a flasher bulb problem. (As per the request of my mechanic, who has no idea what the problem is) As I need turning signals, I really need help!
Mar 15, 2010 at 3:45 PM
Hi mercyelvira42, Welcome to 2carpros and TY for the donation
You need to have the turn and hazard switch assembly tested-the turn signal circuit goes thru there. A problem with the switch will cause your problem even though the hazards works-
Mar 15, 2010 at 6:26 PM
MERCYELVIRA42
Thank you so much for your quick response!
Mar 15, 2010 at 6:40 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 18, 2010 at 12:26 PM
