Computer problem
1993 Chevy Lumina 6 cyl Front Wheel Drive Automatic
Vehicle is Lumina APV (van) w/3800 engine. When started and engine is running AC will not power up, fan is not running either. Anti-lock light is on, Check Engine light is on. Pwr windows will not operate. Turning ignition off then back on after short wait will reset everything and then all will function. This has happened twice. After restarting vehicle ran fine except once as stated below.
There was one occurance where, while driving along after starting at another location, AC shut off (fan included) & windows did not function. I did not observe whether the 'anti-lock' light was on. Engine did not respond as per normal, sluggish. Again, I pulled to the side of the road, shut ignition off and waited for a count of 5 then restarted engine. Everything functioned again. It ran fine for about 1 hr. while returning home. I started the engine again the following day when the first stated sympton recurred.
I have checked numerous electrical plugs and have not found anything so far. Auto Zone & Advance Auto cannot give info for the vintage of this vehicle and the dealer is of no help unless I bring it in (surprise)
Jul 20, 2009 at 11:51 AM
