1992 Chevy Lumina Electrical ( Fuel Pump only gets 8.84 vol
1992 CHEVROLET LUMINA
11,700 MILES • 6 CYL • 2WD • AUTOMATIC
URGUZMAN
Hello, My fuel pump runs when I bypass the ignition switch to deliver 12 Volts direct to it. The wire that runs to the fuel pump only gets 8.84 Volts DC to it so the pump will not run. I have traced the wire to under the dash and it is a Purple wire that also has 8.84 Votls to it. Any ideas as to what the problem may be? I can not find the actual point where the drop in voltage may be. I have bypassed most connectors but I still have 8.84 volts to it.
I have read all other comments and do not see this problem being mentioned. Thank you.
Jul 29, 2009 at 10:46 PM
Did you check at the fuel pump relay?? could be there that's dropping it-
Jul 29, 2009 at 10:50 PM
URGUZMAN
Yes I had checked for voltage there but was not sure, I will recheck it again. at least I can be on the right direction. Thank you rasmataz
Jul 30, 2009 at 11:10 AM
