Six months ago I had new rotors, calipers and pads put on the front of this Lumina. The brakes were bled at the time. After 11,000 miles, I noticed that there is considerably more wear on the left side pad and rotor than on the right side...at least double. I would estimate that the pad on the left side is at least half worn out, and the rotor looks to have lost between 1/16 and 3/32 of an inch of material. I brought the car back and told the shop that either the caliper was faulty or hadn't been lubricated properly. I was told that the left front system wasn't working correctly because it's connected to the right rear that needs to be replaced. I find this a bizarre explanation. Can you help me with some facts about how this brake system works?
Thanks, Steve
Thanks, Steve
Nov 15, 2009 at 6:25 PM
