if your motor mounts are wore out will it stop your car from going backwards
Feb 3, 2009 at 2:10 AM
DOCFIXIT
CERTIFIED EXPERT
Don't believe so might shudder or clunk but would stll back up. Transaxle most likely.
Feb 3, 2009 at 10:47 AM
GLENN35
MEMBER
can it be the transmission. it still goes forward not backwards or is transaxle the samething. can the transaxle be fix with out getting a new or use transmission.whats cheaper to be rpaired a transaxle or a transmission. thanks for ur response very helpful .
Feb 6, 2009 at 4:40 AM
DOCFIXIT
CERTIFIED EXPERT
Yes transaxle and trans sameo. Sometimes a used trans is cheaper because a rebuild is labor intensive.Make some calls but first take to AAmco they run a free diagnostic then you will know
