1990 Chevy Lumina Low vaccum
1990 CHEVROLET LUMINA
DRUMMER1252
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic 1.6K miles
1990 Chevy Lumina, 3.1 V6, auto trans. NO CODES display. Vaccum test gauge reads "retarted timeing" at idle. I cannot find a vacume leak. Car hesitates when fuel pedel is first pushed, then accelerates fine. I changed throttle position sensor, no change. I unplugged the Knock sensor, makes no change in reading on vaccum gauge and sets no chk eng code while unplugged. I was originally checking vaccum to transmition modulator valve for cold 1st to 2ond shift problem. Timming chane??? Bad computer or connection???
Sep 21, 2008 at 5:23 AM
Your vacuum gauge reading does it look like below it represent a retarded ignition timing
https://www.2carpros.com/forum/automotive_pictures/12900_vac12_1.gif
Check your ignition timing and MAP sensor
Sep 21, 2008 at 5:34 AM
DRUMMER1252
No. The gauge is steady about 15. The vaccum guage has a portion marked "timming retarded." The car has no timing marks on crank balencer. Also no distributer.
Sep 21, 2008 at 7:49 AM
