engine runs fine until warm with no miss. After engine is warm, engine misses at idle. Drops number three cylinder. Plug wire good, spark good to cylinder. compression good. restart car warm, drive to 45 miles an hour, let foot off accelerator and check engine light comes on. code reads: EGR bad.(code 32)
Replaced EGR, checked for vacuum leaks.
replaced plug. Problem still there. Like clockwork, same process, same result. When car is warm, check engine light comes on upon deceleration from 45 mph. appears to be a dead cylinder at idle #3.
pull plug wire, plenty of spark. no change in rough idle when plug wire is removed.
Apr 3, 2010 at 9:04 PM
