1990 Chevy Lumina cracked manifold
1990 CHEVROLET LUMINA
65,000 MILES • 6 CYL • FWD • AUTOMATIC
LCARTY
1990 lumina died on freeway 3 times, got it towed.
replaced fuel filter, egr valve cleaned,won't stay
running.Noticed a crack on intake manifold. could this
be the problem? or ecm? fuel injector # 2 had been
replaced june 2007,ran great, til jan 2008.help
Mar 6, 2008 at 11:50 AM
ED ARMES
  • 129 POSTS
A cracked intake will definitely affect how the engine runs but it should not just shut it down. It should only idle rough in park or at stop signs. It scews up the readings recieved by the computer and the computer fights to keep the fuel mixture correct from air coming in where it is not supposed to.
When you are at full speed the throttle body is open more and reduceing the affect the crack causes. The only way the crack could cause the engine to fail at highway speeds is if the engine heat expands the crack to over ride the computers ability to cope with the problem.
Have you tested to see if the crack is actually open?
Spray some carb cleaner in the vicinity of the crack and see if the engine responds in any way like a rougher idle or faster idle. If it does then the crack is open. It is just possible that you are simply seeing a blemish in the casting that looks like a crack.
Mar 15, 2008 at 11:09 AM
