zx2 shakes
CHEVROLET IMPALA
ZX2GUY
same 03 zx2 the one i want to keep but it needs something i cant put my finger on. this might not actually be more then an adjustment problem but i figured ild ask... the motor vibrates, this causes a minor hum and shake within the cab. put it in gear and the car shakes worse, even the steering wheel shakes, its to the point i wonder if something is a tad off. im wondering if its common in the model. ive had several other front drive automatics with 4 bangers and none of them have done this... or at least not to this degree.
Jan 3, 2006 at 7:58 PM
BONNIESBOYTOY
  • 11 POSTS
How old are the tires?? I've seen good looking tires that were "rotten" from too much sitten,and they caused a similar problem when nothing else could be found..
Jan 7, 2006 at 3:26 PM
PALCO
  • 83 POSTS
my 00 kept going thru front motor mounts. i knew when to replace it because of the shake. those zx2 engines had a lot of torque twist. never had it in the steering wheel though. good luck.
Jan 7, 2006 at 3:59 PM
