oil leak in lower intake gasket & upper plenum engine co
CHEVROLET IMPALA
CTFAMILLER
2000 Impala 140,000 Miles
Took car in for servicing and tech said we need to replace a lower intake gasket because oil is leaking.On service date also identified needing upper plenum engine cover - said that is too leaking.
Total repair cost of $1,288.
We never see any oil. Had experienced check oil light once (added oil) but not again.
Car doesn't seem to be using excess oil between changes which we get done regularly
Any ideas?
Oct 23, 2007 at 10:17 AM
2CARPRO JACK
  • 11,533 POSTS
Those did go through intake gaskets. Have you had any low coolant issues, they usually leak coolant, but oil is not unheard of. The upper only carries air, not sue what is leaking there. If you do have th ework done, be sure to have them replace the oil pump drive o'ring (used to be the distributor o'ring) they leak oil all the time and are mistaken for rear main seal leaks
Oct 23, 2007 at 11:42 AM
